Author Topic: mk2 fuel pump  (Read 1103 times)
Offline popleyruss
mk2 fuel pump
« on: 17 November 2010, 21:34 »
Can I fit a vr6 out of take fuel pump to my 16 valve one I have a vr6 engine in i just wonderd if it was the same part
Just plain dubbin
Offline Simeon
Re: mk2 fuel pump
« Reply #1 on: 18 November 2010, 10:15 »
Not sure exactly what you've tried to write there, but I assume you are asking if you can fit a mk3 Vr6 intank pump to your mk2 .. not into the mk2 tank, but if you have the complete mk3 tank you can fit that and remove the mk2 under-car pump. It's a tidy mod :) get the mk3 undercar fuel filter housing too (bolts straight to two of the bolts used for the mk2 undercar pump) and connect it all up. You want the connector for the mk3 pump too so you can splice it into your wiring.
