Author Topic: Trolley jack points?  (Read 15544 times)
Offline Hartside
« on: 17 November 2010, 19:41 »
I changed my wheels over at the weekend for winter but ended up using the VW jack/jacking points. Can anyone tell me the best point or the VW recommended point to use my trolley jack? I don't fancy raising the car on the same jacking points in case it distorts the locating edge for the std car jack
« Last Edit: 17 November 2010, 19:49 by Hartside »
Carbon Grey 5dr GTI
Offline mac7
Re: Trolley jack points?
« Reply #1 on: 17 November 2010, 23:27 »
Look here and here.
Golf R
Offline Keithuk
« Reply #2 on: 18 November 2010, 12:24 »
You would lift the car with your trolley jack on a load bearing member as the sills aren't actually load bearing.  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline rjwojcik
« Reply #3 on: 18 November 2010, 12:25 »
Shocked to hear about the trolley jack points, why aren't they standard.  So, if you take your car into a garage, were do they put their jack?  O-err
Current:
2018 RS4  - Navarra Blue / Black
Gone:
2016 A6 BiTDI - Midnight Blue / Black
2016 Golf GTD with a "lot" of toys
2016 M3 CP - Mineral Grey / Black
2009 135i - Le Mans Blue / Black
Offline Hartside
« Reply #4 on: 18 November 2010, 17:40 »
Quote
You would lift the car with your trolley jack on a load bearing member as the sills aren't actually load bearing.  wink
No sh1t Sherlock, that's the question I'm asking as there is no suitable, obvious load bearing member to see, rather than do damage  :laugh:
Thanks mac7, that's got to be an essential purchase for me. So I'm going to get the following:
8P0 802 845 x1
8P0 802 846 x1
8N0 804 583 x4
8P0 802 847 x2
It'll help loads when I come to change the winter wheels back, but also give me peace of mind the first time I have to let the tyre monkeys anywhere near it. I'ts off to the Audi garage for me!
Carbon Grey 5dr GTI
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 20 November 2010, 11:04 »
It does say were in the manual  :wink: oddly iirc its different to what it said in the mk5 one :undecided:
The dealers use the jacking points on the sill as they are strengthened as can be seen by the thickiness of the metal in the jacking locations.
Current Garage:
35+ years of GTI ownership.
Offline Hartside
« Reply #6 on: 20 November 2010, 17:33 »
I had a quick look in the manual (god I hate that book with a vengeance!) and also on Elsawin. Must have missed it! Come spring I'm getting those jacking points as it will make the whole job a hell of a lot easier I think
Carbon Grey 5dr GTI
Offline rgb
« Reply #7 on: 12 April 2011, 20:42 »
Is this really the only way to jack the car up with a trolley jack? Can I achieve the same effect with a block of wood on the head of the jack?
Thanks
Offline Buck
  • Das Auto
« Reply #8 on: 12 April 2011, 22:15 »
Quote
8P0 802 845 x1
8P0 802 846 x1
8N0 804 583 x4
8P0 802 847 x2
I'm on my iPhone so haven't looked in detail but if the above are the rubber bunts, be careful, they are not designed to be load bearing when used as single jacking points.
If you use a trolley jack you can place a stand at the front under the engine/suspension mount iirc and at the rear if you jack a little higher the rear wheel will come off the ground and you can place a stand under the rear sill.
If your trolley jack has a flat head you can use an ice hockey puck with a groove cut in it to fit over the sill to prevent distortion but the sill IS weight bearing at the marked points so should be no issue
HTH
Offline Hartside
« Reply #9 on: 13 April 2011, 18:23 »
I found the puck was too shallow to be able to cut a deep enough groove into. I wanted to be able to contact the reinforced floor area with the face of the pad. I got one machined out of Polypenco (nylon) and had to cut a slot 15mm wide x 25mm deep to get it to do this. Makes the job a whole lot simpler:
Picture is crap but you get the idea
Carbon Grey 5dr GTI
