Author Topic: annoying fuel problem-please help  (Read 3887 times)
Offline 15 inches
« on: 22 August 2003, 23:23 »
 :-[I have a mk2 8v,pb gti.
When you take your foot of the accelorator the car seems to jerk,rather than gradually ease down.
This started some months ago,the car drives great whilst accelorating but when you come off the gas say in traffic the car feels like its in the wrong gear .
If you drive in first and take your foot off the gas its as if the fuel has been cut and the car jerks forward,then again when you press the accelorator.If you came on and off the gas in 1st ,the car would kangaroo down the road..
After much advice >:(and ???'s spent, the car is still the same
replaced:-cambelt -battery,fuel filter,dissy cap and rotar arm,leads and plugs tci-h switch,air flow meter,idle speed valve and coil.The car has been set up by a VW centre and runs on 98ron fuel.
The car has a stainless steel exhaust and k@n pannel filter-its also my pride and joy please help
regards..
Offline mk1
Re:annoying fuel problem-please help
« Reply #1 on: 23 August 2003, 07:20 »
Check the throttle switches, sounds like the closed throttle swich is faulty. Also check the ign timing, may be to advanced, Steve
Offline 15 inches
« Reply #2 on: 23 August 2003, 09:44 »
Cheers steve,ill have ago at that.
Offline richandhazel
« Reply #3 on: 23 August 2003, 11:42 »
Totally agree with Steve......exactly what went through my mind when reading your problem.
golfvr6
« Reply #4 on: 23 August 2003, 17:00 »
Can you adjust the ignition timing on digifant, not sure if you can on the later ones. If the cambelt has been done it might be worth checking that the static timing is spot on.
« Reply #5 on: 23 August 2003, 17:06 »
Ah yes, PB is digifant isn't it.......good point golfvr6.
golfvr6
« Reply #6 on: 23 August 2003, 17:08 »
Has the Digifant got throttle valve switches or just a potentiometer or both?
« Reply #7 on: 23 August 2003, 17:14 »
It does have the throttle valve switches.
golfvr6
« Reply #8 on: 23 August 2003, 17:16 »
If the throttle valve switch is faulty then the car tends to try and cut out when approaching roundabouts etc... I'm not convinced thats the problem in this case.
