Author Topic: Dodgy Temp Gauge?  (Read 2775 times)
Offline thatwillis
Dodgy Temp Gauge?
« on: 16 November 2010, 21:30 »
Hi Guys and Girls
I saw the other thread on temperature gauge but my symptoms are slightly different.
The temperature gauge would some times not move at all when I have been driving for 20 mins.  It would also get to temperature then drop randomly.
This morning i started the engine and the temperature light came on beeping at me although there was no fluid or over heating.
Am i right in saying it needs the temperature sensor replacing?
James
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dodgy Temp Gauge?
« Reply #1 on: 16 November 2010, 21:33 »
yes more than likelly mate..
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 16 November 2010, 22:04 »
Could be the thermostat if not the coolant sensor?
Offline thatwillis
« Reply #3 on: 16 November 2010, 22:08 »
Is the coolant sensor the one in the expansion tank? That looks lovely and easy to change?  :tongue:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #4 on: 16 November 2010, 22:19 »
Nooo
Has a green top to it.
« Last Edit: 16 November 2010, 22:22 by s-l-i-x »
Offline thatwillis
« Reply #5 on: 16 November 2010, 22:27 »
oh i see great cheers I'll take a trip along to GSF and see what i can find on friday.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 16 November 2010, 22:44 »
you will see it as it has a green ring around it its help in with a circlip.. 5 min job and no need to use any coolant  :wink:
Offline thatwillis
« Reply #7 on: 16 November 2010, 22:57 »
Ill try that first then  :wink: Thanks  :smiley:
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #8 on: 17 November 2010, 00:23 »
Try get a sensor from vw there was only a couple of quid difference when mine went.
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline Adam
« Reply #9 on: 17 November 2010, 05:04 »
Part numbers and prices from TPS.
mk4 Golf 1.8T Temp Sender (Green) -     £23.70 exc VAT -       Part Number - S059919501A
mk4 Golf 1.8T Temp Sender Retainer      £0.38 exc VAT           Part Number - S032121142
mk4 Golf 1.8T Temp Sender O'ring          £0.85 exc VAT           Part Number - N90316802
Down Hill From Here.
