Author Topic: 16v engine and gearbox brackets  (Read 2171 times)
Offline Dan_GTi8v
« on: 16 November 2010, 21:23 »
as title, where can I get these from I'm having real trouble finding some? people breaking wanna keep them and not sure how to get them from scrappies as there attached to the engines!
Offline AlexMozza
Re: 16v engine and gearbox brackets
« Reply #1 on: 16 November 2010, 21:23 »
GSF?
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Dan_GTi8v
« Reply #2 on: 16 November 2010, 21:31 »
I was under the impression these would be expensive new? I cant search online as I dont have a reg (its for a conversion), but the only thing I can get from the gsf website is a front bracket. might give ecp a ring in the morning
any idea how much they are new?
Offline Dan_GTi8v
« Reply #3 on: 16 November 2010, 23:33 »
OK next question, how many do I need for a full set, is it 2 rear 1 front and 1 gearbox? So like I ask for rear left, rear right, front, and gearbox? sorry if it sounds retarded but I dont know!
« Reply #4 on: 16 November 2010, 23:40 »
Are they not the same as a 8v.
Offline Dan_GTi8v
« Reply #5 on: 16 November 2010, 23:45 »
Apparently they are slightly different, I got this from rubjonny and been told the same by a couple others
the actual mounts on the car are the same physical shape on all models, vr6 are strongest so fit those. the front and rear brackets on the block again they need to be from mk3 or seat 16v or tdi. cant use vr6 engine one as block totally different shape. gearbox ones can come from abf, tdi or vr6.
you cant use 8v brackets as they're for cars without cable clutch, this is why you need abf/tsdi ones as they position the block a little differenty  hope all that makes sence!
« Reply #6 on: 16 November 2010, 23:47 »
I am confused RJ is saying 8v is not cable clutch yet it is  :undecided:
Offline Dan_GTi8v
« Reply #7 on: 16 November 2010, 23:48 »
yeah I think he meant hydro :P we were having a chat about clutch cylinders before hand so maybe got a bit confusing :)
« Reply #8 on: 16 November 2010, 23:49 »
Not sure then, keep looking s/h is your best bet.
Offline Dan_GTi8v
« Reply #9 on: 16 November 2010, 23:52 »
am I right in the amount I need though? 2 rear 1 front and 1 gearbox? I feel like a reatrd for not knowing this lol
