Author Topic: Help ASAP!!!!!  (Read 744 times)
Offline ashbreed
Help ASAP!!!!!
« on: 16 November 2010, 20:04 »
Sitting out here in the cold lookin 4 my vag com port..... Were is it?!
It's not in the ashtray before n e 1 says!
It's a 92reg mk3 if that helps!
Offline snifferdog
Re: Help ASAP!!!!!
« Reply #1 on: 16 November 2010, 20:13 »
Behind a plastic cover to the left of the tray!
Offline *tell*
Re: Help ASAP!!!!!
« Reply #2 on: 16 November 2010, 20:16 »
yer pull the ashtray out complety and slide the plastic
part to the right.  :smiley:
Offline justalex81
Re: Help ASAP!!!!!
« Reply #3 on: 16 November 2010, 20:22 »
thought it was in a different place on a 92 plate, and also you need an adapter for the vag-com lead as it's not an obd port.
I could also be talking out of my arse but i'm sure i saw a thread recently about it!
Offline ashbreed
Re: Help ASAP!!!!!
« Reply #4 on: 16 November 2010, 21:28 »
Found it! and ur right mate. They're a pair of 2 pin plugs above the ashtray and below the heater controls. Behind 2 blank spacers (in-between heated rear windscreen and AC buttons.)
So if anybodys got a 92" mk3 golf u now know wer it is!
