Author Topic: New Member In Need Of Assistance!  (Read 1992 times)
Offline louloubelle
« on: 16 November 2010, 13:49 »
Hello to everyone.  I'm new to the forum and in need of some assistance.  I have a P-reg MK3 8V GTi which has a tendency to stall when cold and occassionally when hot.  When I start her up there appears to be little or no choke, which obviously causes the stalling. It idles below 1000rpm.  Alas, as this morning was the 1st cold one of the year, the car turned over but would not start.  Other than this it is a great car so I would like to get the problem fixed!  Relay 30 has been changed, injector cleaner has been run through it and the top breather hose has been changed.  Any pointers would be gratefully received!
Offline N900 MJT
Re: New Member In Need Of Assistance!
« Reply #1 on: 16 November 2010, 13:54 »
Hi and Welcome!
Firstly i would check here : http://www.golfgtiforum.co.uk/index.php?board=8.0
If you still cant see what you are looking for then use the search button at the top and see if that narrows it down a bit.
Once mine has warmed up a bit it idles at about 800rpm so that looks normal
Offline Guy
« Reply #2 on: 16 November 2010, 13:58 »
clean the throttle body.... job done :)
Offline louloubelle
« Reply #3 on: 16 November 2010, 14:10 »
Thank you.  I've printed off pages of possibilites!  Will clean the throttle body first and then it's a process of elimination!
Offline N900 MJT
« Reply #4 on: 16 November 2010, 14:12 »
Welcome to owning a MK3!!!
Offline dubstep dsob
« Reply #5 on: 16 November 2010, 15:12 »
if it doesnt solve the problem by cleaning the throttle body. give the mass air flow sensor a clean also  :smiley:.
it aint dubbing unless its rubbing
Offline snifferdog
« Reply #6 on: 16 November 2010, 15:39 »
Welcome, have a look through the maintenance section too!  :smiley:
http://www.golfgtiforum.co.uk/index.php?board=57.0
Offline SAM HOWSON
« Reply #7 on: 16 November 2010, 16:08 »
hellllllllllllllllllllllllppppppppppppp
Offline Guy
« Reply #8 on: 16 November 2010, 18:20 »
:huh:
Offline GOLF_STU
  • THE_GIT
« Reply #9 on: 16 November 2010, 21:33 »
:huh:
hmmm how odd   :huh:
welcome along anyways  :smiley:
V TEC KICKED IN Y'ALL!!!
