Author Topic: side light  (Read 2393 times)
Offline mossy1969
side light
« on: 16 November 2010, 06:04 »
hi just had an bulb indicator on the dash board saying the side light bulb is off ,question is it much of a job to change,,,,,thanks
Offline weston
Re: side light
« Reply #1 on: 16 November 2010, 07:57 »
Simple. You need 1 x w5w 501 bulbs, some brute force, a choice selection of expletives and probably a blood transfusion for your hand injuries afterwards. You have to pull the holder harder than you'd expect but it's not too hard.
Offline Gene Hunt.
Re: side light
« Reply #2 on: 16 November 2010, 15:17 »
............as above not hard job just not a lot of room. Best thing i did was to get a good hold on the bulb holder as close to the rear of the light lens as possible & then just rock/twist & pull the holder & it will come out.DON'T try to remove it by pulling the wires. :smiley:
Candy White ED35.
Offline AlanD
  • MK5 2.0T 16v
Re: side light
« Reply #3 on: 16 November 2010, 15:50 »
I ended up using some pliers to get mine out as it just wouldnt budge otherwise.
Offline mossy1969
Re: side light
« Reply #4 on: 16 November 2010, 18:46 »
so knowing my luck it will be a nightmare ,first aid kit at the ready then
Offline Gene Hunt.
Re: side light
« Reply #5 on: 21 November 2010, 07:30 »
.........have you done it? :grin:
Candy White ED35.
Offline Jimp
Re: side light
« Reply #6 on: 21 November 2010, 14:52 »
Long nose pliers are great for this job. I still cut up my knuckles getting the driver's side one though  :grin:
Not low enough mk5
Not on the road enough mk3
Offline Gene Hunt.
Re: side light
« Reply #7 on: 22 November 2010, 19:57 »
........did you remove the black filter box from it's holder ?. :wink:
Candy White ED35.
Offline Jimp
Re: side light
« Reply #8 on: 22 November 2010, 23:11 »
Mine is only a 1.4 so the engine bay layout is a bit different. On my driver's side there was some...thing?... in the way, but it wasn't a filter box anyway. Looked like the power steering fluid reservoir on a mk3 but being honest I don't know what it was.
Not low enough mk5
Offline AlanD
  • MK5 2.0T 16v
Re: side light
« Reply #9 on: 23 November 2010, 09:22 »
On the GTI its the fuel filter that gets in the way on the drivers side, Im guessing it will be the same on yours.
