Author Topic: drivers side seat stuck  (Read 1481 times)
Offline trafficfaceGTI
« on: 15 November 2010, 22:19 »
my drivers side seat seems to be jammed in the worst driving positioned for my long legs, whats going on with the subframe?
is this a common problem i just want to slide it back, the passenger one is fine.
any ideas?
Offline rowleyslims
  • hakuna mutata
Re: drivers side seat stuck
« Reply #1 on: 16 November 2010, 00:54 »
ive dwelt with that problem before. mine gets stiff at times and it seems you have to push STRAIT back to get the seat to move (if pushed even in the slightest angle seat wont move an inch). if that doesnt work then best advise i could give is compare a model (passengers side maybe?) of what its supposed to look like with what you got goin on with your drivers side. hope this helps.  :rolleyes:
after you get it fixed to the distance you want it back just dont eff with it haha  :wink:
« Last Edit: 16 November 2010, 00:56 by rowleyslims »
« Reply #2 on: 16 November 2010, 03:27 »
ok i will give that as go tommorow, im so board of not being able to get in the car without sitting on the floor outside and throwing my legs in... ok so its not that bad :)
« Reply #3 on: 16 November 2010, 10:01 »
have a look under the front seat while you move the slider handle, it might be the handle has popped out of the release pin? if not see if seat slides forward, if it does have a good look in the chanels to make sure summat hasnt fallen in there and jammed the seat
Offline lewis1641
  • stuck in the 90's
« Reply #4 on: 16 November 2010, 12:20 »
Has it ever moved?
Spray some grease on the runners. Might help.
I had bother with one of mine. Ended up giving it a gentle tap with a hammer at the front. It moved!
« Reply #5 on: 17 November 2010, 01:02 »
i couldn't push it in any way, so i had a look under as best i can and i saw the spring move back and forth fine, so it might well be a physical jam in the runners, its greased up fine too.
