Author Topic: Cooling system hoses and some questions??  (Read 3121 times)
Offline Snap
  • Just smile, stop being miserable!! :-)
« on: 07 February 2005, 20:37 »
Hello all,
1) My mk2 golf's coolant hose, the one next to the airfilter, split whilst i was driving. AA man did a temp fix for me but i need to change the hose. So i bought the top and bottom hose. Any tips??
2) The haynes manual's a bit fuzzy. Is the halfords manual any good?
3) Is the a part manul online apart from that russian one?
4) I also bought coolant but its 1.5 litre. Will the be enough after I refil the whole system? Or do i have to dilute it?
Cheers.
'92 1.8 Mk2 Golf, carbed GU... [SOLD]
Offline mk1
Re: Cooling system hoses and some questions??
« Reply #1 on: 07 February 2005, 21:04 »
Take your car to the main stealer and show them the hose you need, mix the antifreeze 50% with water. I would drain the cooling system and refill with fresh coolant, that way you know that there is the correct amount in the system.
Steve.
Offline ...joe
« Reply #2 on: 07 February 2005, 21:22 »
coolant hose next to air filter? i guess thats the top radiator hose so just unclip the old one and clip the new one in its place, mix the coolant and jobs a goodun........... or am i answering the wrong question? it shouldn't be hard to swap a hose or two!!!
if you are going to drain your system,after you've topped it back up, give all the hoses a good squeeze when you think the system is full of coolant to get rid of air bubbles then let it run up to temperature with the filler cap off to allow all the air to work its way out. then top up to the correct level and put the cap back on.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Snap
« Reply #3 on: 08 February 2005, 13:24 »
I will be draining the system but will 1.5L of coolant be enough to refil the whole system?
My old coolant was green and i seem to have bought pink coolant. Is that gonna be a problem? Should i just stick to green?
Thanks.
Offline ...joe
« Reply #4 on: 08 February 2005, 23:38 »
shouldn't worry too much about the colour!!! as long as its decent stuff it doesn't matter. i know a guy who hass the pink stuff in his g60 and he uses it because he has got a load of clear hoses and it looks cool!!!
can't seem to find any definate figures for the amount you'll need but that sounds about right.
« Reply #5 on: 09 February 2005, 12:18 »
Check what coolant you bought, if its G12 it wont mix with the olds stuff IIRC.  Did you buy it from VW?  If so it is likely to be G12+ which is more purpley and can be mixed with anything :)
Offline Snap
« Reply #6 on: 09 February 2005, 18:35 »
Photo 1
Photo 2
I bought the wrong hoses and i have been talking about the wrong hoses. D'oh!!
The hose i need is thin and comes out of the auto-choke (i think) as circled in photo 1 (where it split). It goes around under the airbox and joins as show in photo 2.
Can i only buy this at the dealer?
« Reply #7 on: 10 February 2005, 09:33 »
I might have one of those in my bits box, you live near Bracknell?
Offline Snap
« Reply #8 on: 10 February 2005, 16:43 »
Darn i wish i had read this earlier. Thanks for the offer jonny but i have ordered if from my local stealer but had i read this i would have picked it up from u.
Im gonna be flushing the system as aparrently they dont make green coolant anymore - i dont mind doing it anyway coz i can clear the system. I have bought pink coolant.
Will i have any issues about clleaning the coolant expansion tank?
Thanks.
« Reply #9 on: 10 February 2005, 17:12 »
Best way is to remove the hoses, block the holes off, fill it up with water & bleach and leave overnight.  Then flush it all out with a hosepipe and it will come up like new :)
