Author Topic: only getting very slight heat from the heater  (Read 3078 times)
Offline mboon
« on: 15 November 2010, 17:55 »
As a I've. Any ideas why. Car warms up fine
Part of the GTi 16v Flying Squad and the Special Forces //M Department
Offline jimojameso
Re: only getting very slight heat from the heater
« Reply #1 on: 15 November 2010, 18:21 »
I'm afraid its probably the heater matrix matey. Hit the search button for more info.  :sad:
Offline Mk2Kezza
« Reply #2 on: 15 November 2010, 18:54 »
It could be the coolant pressure relief valve thats knackered. Have a search on here for that and i'm sure it will lead you in the right direction.
<br />Almost finished.....
Offline snifferdog
« Reply #3 on: 15 November 2010, 18:56 »
The matrix's are known to fail on the mk2 arent they?! It did on both of my old ones. Maybe the thermostat if your lucky?
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #4 on: 15 November 2010, 19:46 »
Check the heater pipes by squeezing them and listening for crunching. The pipes can fir up inside and restrict the flow. If the pipes are like that, then the matrix is sure to be the same.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 15 November 2010, 19:54 »
If your car has the bypass valves they could be faulty..
More likely the matrix... Feel your passengerside carpet... If it sodden it's 99.999999999999999999999999999% matrix!!
For More Info Click To See;
Offline DarnPB
« Reply #6 on: 15 November 2010, 19:57 »
Or 0.000000000000000000000000001% drooling over a 1.4 MKIII with 13 inch steels. :laugh:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 15 November 2010, 20:29 »
Would have to be alot longer than that before I even looked at a Mk3.... Without laffin and feeling sorry for the owner  :evil:
Offline weazgti
« Reply #8 on: 15 November 2010, 20:37 »
Could just be a problem with the arm on the heater box. try moving it by hand and see if any more heat comes out.
Has any foam blown out your vents?
Offline mboon
« Reply #9 on: 15 November 2010, 20:45 »
Thanks all
 carpets are dry
No foam coming from the vents etc
We are getting some heat its just luke warm. The fan seems to always be on when we park it up but we di have to go slow for a few miles as road bumps. Any way of testing the matrix
