Author Topic: MFA not working  (Read 1121 times)
Offline rtking449
  • Run out Mk2 8v GTI &MkIV Tornado Red GTI
MFA not working
« on: 07 February 2005, 19:29 »
Hello please can anyone help ive got a 1985 GTI in cracking nick everything works except the MFA.The switch isnt faulty as it tells me the oil and outside temp but not fuel consumption does anyone have any ideas?
Re: MFA not working
« Reply #1 on: 08 February 2005, 13:00 »
Check the vacuum pipe connection to the inlet manifold is hooked up to the back of the clocks and the hose is in good nick.  Also try pulling the fuse for the clocks for 30 seconds.  If the milage reading is incorrect, the sender screwed to the rear of the speedo might be knackered?
