Author Topic: Squeeky Brakes  (Read 4665 times)
Offline VWKev
  • Please Support Non-Human Rights
Squeeky Brakes
« on: 15 November 2010, 12:57 »
Anyone had squeeky brakes ?
It's not so bad when breaking hard, but when stuck in traffic and just doing gentle breaking, I will hear a squeek noise just before the car stops or a sort of grinding noise as its about to stop.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline VWKev
Re: Squeeky breaks
« Reply #1 on: 15 November 2010, 12:57 »
spelling fail, that of course should be Brakes   :grin:
Offline am1w
Re: Squeeky breaks
« Reply #2 on: 15 November 2010, 13:03 »
Spelling fail twice:
Squeek should be squeak! :wink:
« Last Edit: 15 November 2010, 15:16 by am1w »
Offline ub7rm
Re: Squeeky Brakes
« Reply #3 on: 15 November 2010, 13:16 »
Normalish, the soloution is to do a few sharp stops from as high a speed as safe ...
2020 BMW 128ti
2017 Golf GTD Estate
Offline rjwojcik
Re: Squeeky Brakes
« Reply #4 on: 15 November 2010, 17:42 »
Your car sounds like a taxi, Kev   :wink:
Current:
2018 RS4  - Navarra Blue / Black
Gone:
2016 A6 BiTDI - Midnight Blue / Black
2016 Golf GTD with a "lot" of toys
2016 M3 CP - Mineral Grey / Black
2009 135i - Le Mans Blue / Black
Offline VWKev
Re: Squeeky Brakes
« Reply #5 on: 15 November 2010, 20:53 »
A few mates I have talked to said it is kinda normal too, but I never hear it in any other car I've been in.
Offline Ess_Three
Re: Squeeky Brakes
« Reply #6 on: 15 November 2010, 21:02 »
That's the answer...I find braking from 80-100 MPH down to approx 10-20 MPH (but not coming to a stop), with about 90% braking effort (hard, but not enough to trigger the ABS), then give 2-3 minutes to let the brakes cool off, repeat the procedure 2-3 times more...then drive round trying not to use the brakes much for the next 10-15 minutes will give the brake discs good coating of brake pad, which should stop any squealing.
I use this method for bedding in any new car or new brakes...and don't suffer from squealing so long as the pads aren't silly hard track pads.
..but gaining motorcycles.
Offline Snoopy
  • Moderator
  • Geoff.
Re: Squeeky Brakes
« Reply #7 on: 16 November 2010, 07:44 »
Basically with light braking you have whats called glazed the pads. Its common on non aspestos(sp?) brake pads with light use.
Theres two solutions well 3 but the 3rd is new pads :grin: 1) brake hard a few times to take the glaze off as others have suggested. 2) The second is remove the pads and as a quick DIY solution rub the pads surface a few times on a concrete kerb to take the smoothness glaze off them. Then refit.
« Last Edit: 17 November 2010, 18:39 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline VWKev
Re: Squeeky Brakes
« Reply #8 on: 16 November 2010, 12:29 »
thanks all.
at least I know now there is nothing 'wrong' as such.
Offline AlanD
  • MK5 2.0T 16v
Re: Squeeky Brakes
« Reply #9 on: 16 November 2010, 12:35 »
Squeaky brakes were a common thing on the MK5, Im assuming they are the same on the MK6? (Im honestly not saying that as some sort of wind up :D). In which case I wouldn't worry about them.
As ub7rm said a few hard quick stop from high speeds worked with varying degrees of success on MK5 brakes.
