Author Topic: Dim-Dip Lights fault finding on a mk2 16v  (Read 3346 times)
Offline mk2rolf16v
« on: 15 November 2010, 02:16 »
Does anyone have experience in fault diagnosis for the dim-dip function for headlights?..... I have a 1990 gti 16valve, and when turning sidelights on, the dim dip feature should switch on. Ive tried things like checking all connections, using a different light switch and replacing the headlight bulbs..... but to no success. I've tried probing around with a multimeter, I'm thinking its most likely the resistor coil, but dont know how to test....
any help would be much appreciated.
Offline dubber36
Re: Dim-Dip Lights fault finding on a mk2 16v
« Reply #1 on: 15 November 2010, 07:43 »
The dim-dip resistor is a packet of polo sized tube that lives on the inner wing behind one of the headlights (can't remember which one) Many of them pack up and cause other problems with the lights so get removed.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 15 November 2010, 11:03 »
Off side.
« Reply #3 on: 15 November 2010, 11:33 »
there are also some yellow wires behind the fusebox for it, 2 a 2 pin or 2 single pin plugs.  the resistor wires can rub thru and short out on the chassis leg, if that happens it sets fire to the headlight loom. i always remove them for this reason as it doesn't really perform any useful task. who needs an extra light level setting between sidelights and dipped beams anyway  :grin:
