Author Topic: Spark Plug Colour  (Read 1733 times)
Offline JonLeeper
Spark Plug Colour
« on: 14 November 2010, 21:29 »
I am giving the old girl a bit of TLC before a track day on Fri and have pulled a spark plugto have a look.  I thought that she was running a bit rich, as she smelt of petrol, but the plug would apear to indicate that she is running a little lean if anything.  The plug is a NGK BP6ET three prong one and the prongs are very grey heading towards white at the very tip.  I have not used these sort of plugs before and so am looking for a little advice before I head off in the wrong direction.  The car is a 179000 mile old 8v, if anyone dosent remember, and has completed a couple of good hard days at Brands this year without major drama.
Any thoughts?
Jon
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Spark Plug Colour
« Reply #1 on: 14 November 2010, 21:31 »
Running lean like yours may be doing will produce a similar smell to running rich. I think your mixture needs tweaking up a tad otherwise you could be causing more problems with a hot mixture. Don´t forget to increase your idle when you richen up as it will drop a little.
Offline JonLeeper
« Reply #2 on: 14 November 2010, 21:46 »
Is that a considered opinion that it is running lean based on the colour or just my description?
Offline clipperjay
« Reply #3 on: 14 November 2010, 21:54 »
Plug chops are only good when you drive it hard, suddenly stop then have a look  :wink:
Or you could always buy an air to fuel meter see what readings you get loads of money though  :sad:
Offline DarnPB
« Reply #4 on: 14 November 2010, 21:56 »
Your description of the colour and the smell.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #5 on: 15 November 2010, 11:13 »
