Author Topic: MK4 GTI 1.8 T Tuning/chipping help  (Read 4887 times)
Offline mk5rst
« on: 14 November 2010, 16:21 »
Hi all, im new to this forum, i have recently got myself a nice 1999 GOLF MK4 GTI 1.8T After a long time of owning fords i have finally seen sense  :cry: LOL, However i find it a bit flat compared to some of the other things ive had, whats the best way to get a bit more out of the 150 engine?im looking along the lines of a decat pipe, filter, chip/remap but unsure of the best things to go for, im sure you guys will put me right, cheers in advance. Pete    :smiley:
Offline JDM82
Re: MK4 GTI 1.8 T Tuning/chipping help
« Reply #1 on: 14 November 2010, 17:34 »
You cant go wrong with a quality exhaust system including a sports cat or de-cat. I have a milltek which I can highly recommend. Then there's upgrading your standard engine parts ie DV,plugs,filter etc then you'll be ready for a re-map. A stage one re-map with some simple mods will take the bhp up to approx 195-210. Forge make a good replacement DV,the 007, which is a recirculating DV, you can't/shouldn't put a atmospheric DV on a golf if you didn't know.As for filters, if your keeping your standard panel filter set up then I suggest a pipercross filter. Or you can get a cold air induction kit.  Depending on where you are or if your willing to travel you should speak to the lads at R-TECH about the re-map. There's loads of build threads to look at on here to give you ideas and the GOLFGTi members are full of advice and tips.
Check out the site classifieds for parts etc. You get some great bargains!
www.Awesome-gti.co.uk is a great site for parts,styling etc but they are quite expensive.
Also if your serious about a re-map and go to R-Tech then they sell and fit all the performance upgrades you'll need with some great advice too. www.r-techpower.co.uk
Welcome to GOLFGTi.co.uk  :smiley:
« Last Edit: 14 November 2010, 17:41 by JDM82 »
GOLF GTi - The legendary hot hatch
Offline mk5rst
« Reply #2 on: 14 November 2010, 19:08 »
Thank you for your help,it has new genuine coils, forge dv, when i give it a service i will add a decent filter and use good oil, do you have a rough idea what these guys charge for a re-map? cheers. pete
Offline JDM82
« Reply #3 on: 14 November 2010, 22:27 »
I think I was quoted £250 but that was a while ago. You'd be better off giving them a ring. You can ask a question on the R-TECH section but its faster to ring them. Prices depend on engine code I think, I may be wrong but either way the answers just a phone call away  :grin:
