Author Topic: drainage holes in sunroof of a mk 4  (Read 873 times)
Offline reecysmummy
« on: 14 November 2010, 12:13 »
hi all i was wondering could anyone help me my boyfriends sunroof is leaking its an electric sunroof we cant find the drainage hole to see if there blocked
Offline vwprime
Re: drainage holes in sunroof of a mk 4
« Reply #1 on: 14 November 2010, 12:41 »
With the sun roof all the way open you will find the front drain holes in the corners. Give the holes a prod to try and cleen them up. If you open the front doors you will find a black ruber gromit inbetween the two hinges that sticks out. If you play with this by open you will probably get a lot of crud fall out of it. If you have a air line it would be good to blow down the drin hole and try and keep the ruber gromits open to pust the rubish out. Hope that helps :)
TRANSFORM, & ROLL OUT!
Offline rosko-rs
« Reply #2 on: 18 November 2010, 21:52 »
not only in front, a rear until the rear bumper, tail lights in the trunk passes under the hose, there shall membrane
