Author Topic: Front cross member bolts,  (Read 5223 times)
Offline Simeon
Re: Front cross member bolts,
« Reply #10 on: 15 November 2010, 10:20 »
Just replace the two front crossmembers, they're very cheap secondhand, I've got a pair for sale for a tenner.
Offline rob.043
« Reply #11 on: 15 November 2010, 11:09 »
Could the excess movement be worn CV joints? (Im wondering about this for my own car too, what play/wheel rotation is acceptable accross the axle?)
Also consider the other two engine mounts (rear mount and gear box mount), if they are old and fooked, they could probably do with replacement too to reduce engine movement.
Offline beechymonza
  • mad beech
« Reply #12 on: 15 November 2010, 17:39 »
No i dont think its worn C.V joints,
This like a movement as if other engine mount or gearbox mount has probably gone,
No guts No glory,
Offline rob.043
« Reply #13 on: 15 November 2010, 21:54 »
Similarly, could nackered/loose diff rivets be partly to blame?
Probably is the mounts.
I believe it is recommended to get the G60 spec rear engine mount, and the 1.3 model gear box mount. As these are the solid rubber ones of the best design. All will fit.
