Author Topic: Does this nightmare ever end....................(vagcom problem)..  (Read 1034 times)
Offline Andy3277
I have had my 8v 2.0 1996 for around 2 months. After trawling this site it has proved successful But 1 last problem (fingers crossed) i have changed loads on the car and recently purchased VAGCom and it arrived this morning. Happy days i thought the problem is the VAGcom is saying that the iso/0bd-11 is not compatible with my car. So i'm stuck in a rutt and asking for help any ideas.........oh i'm running windows 7 from a HP laptop if that helps.
Offline dom
  • Back in a Mk4
Which version of windows 7? I'm running 64bit and can't get it to work, although I borrowed a laptop running the 32bit version and could get it running.
Also which version of the software are you running?
Offline Andy3277
mmmm thats thrown me i will have to get back to you with that one....the program is 409-1 the laptop is 32 bit and its windows vista not windows 7 sorry
Offline dom
  • Back in a Mk4
You could try using VCDS lite software instead  :undecided:
Offline Andy3277
tried both still no joy tried updating the driver starting to get on my nerve's now don't know what to do :angry:
Offline Andy3277
finally sorted
                 i have sorted out my vagcom next problem my hall sender is out of range any ideas....!
Offline dom
  • Back in a Mk4
finally sorted
As per my reply in your other thread, new hall sender needed!
that code usually means the dizzy timing is out rather than actual failure, but it could be dead. also check wiring to it
