Author Topic: r reg mk3 golf steering issue  (Read 784 times)
Offline glyndawn
« on: 13 November 2010, 16:37 »
the power steering belt is slipping on my car and when on full lock it sqweels is there any adjustment on this to tighten it up ?
Offline dom
  • Back in a Mk4
Re: r reg mk3 golf steering issue
« Reply #1 on: 13 November 2010, 17:11 »
Just replace it, the belt is only a few pounds and changing it is a simple job!
Offline snifferdog
« Reply #2 on: 13 November 2010, 18:22 »
You can adjust it easily enough, I did mine.
« Reply #3 on: 15 November 2010, 11:05 »
1 13mm bolt driver side which has a big toothed wheel round the outside, another 13mm bolt passenger side thru a slotted hole, and a 15mm iirc bolt where the pump actually pivots.  loosen all 3, then use a large adjustable spanner on the toothed wheel to set tension. want around 3-5mm deflection on the belt. if that doesn't help, replace it. might as well to alt belt while you're there.
