Author Topic: rough tick over  (Read 2744 times)
Offline postie
rough tick over
« on: 13 November 2010, 14:16 »
i have a mk4 130 tdi 51 plate and while i was sat waiting in the local car park the car started to shake on tick over, it did this for about a minute until i reved it up.
is this the MAF causing the problem if so do i need a new one or can it be cleaned
or is it some thing else?
i hope some one has the answer to my little problem
thanks for all and any help on this
2001 130 tdi.
Offline Adam
Re: rough tick over
« Reply #1 on: 13 November 2010, 20:37 »
Get it on Vag-Com to scan for fault codes.
Anything else abnormal for instance the temperature needle shooting up and down?
Down Hill From Here.
Offline postie
Re: rough tick over
« Reply #2 on: 13 November 2010, 22:04 »
temp is on 90 which seems normal. as it go's to 90 all the time and has never gone past it.
2001 130 tdi.
Offline Adam
Re: rough tick over
« Reply #3 on: 13 November 2010, 22:06 »
I  would get it scanned mate. Where abouts are you?
Offline postie
Re: rough tick over
« Reply #4 on: 13 November 2010, 22:09 »
wiltshire, i have a local vw garage about 10 miles away, i will drop in on monday and ask them to have a look on the way back from work
2001 130 tdi.
Offline Adam
Re: rough tick over
« Reply #5 on: 13 November 2010, 22:14 »
Ohh expect them to charge you a fortune for diagnostics. Where abouts in wiltshire? If your willing to travel I can scan it for nothing.
Offline asif
Re: rough tick over
« Reply #6 on: 13 November 2010, 22:40 »
Just remember not to rule the MAF out if it don't come up on a scan as the MAF rarely comes up anyway.
You'd need to do some logging to find out if it's defo gone or not.
MK7 GT Bluemotion Tech TDi 150
