Author Topic: how to remove gti big bumper fog lights?  (Read 1934 times)
Offline mboon
« on: 13 November 2010, 13:19 »
As above. I can see the screw bit which is missing but can't get the whole light out. And DIY guides or tips and hints
Part of the GTi 16v Flying Squad and the Special Forces //M Department
Offline cняis
Re: how to remove gti big bumper fog lights?
« Reply #1 on: 13 November 2010, 13:35 »
easier to do with the bumper off, but not impossible with it left on however you might want to jack it up
remove it complete with the mounting bracket aswell, will make things easier
the mounting bracket is held on with 2 coach bolts, the nuts can be reach from behind the bumper, iirc theyre 13mm
hope that helps!
Offline dadrathers
« Reply #2 on: 14 November 2010, 20:09 »
You should be able to remove the light quite easily. Jack up the car so that you can actually get your face in there. Then there should be a flat head screw that keeps it in place. Remove this and then on the other end from the screw there is a lug that fits into the bracket. There should be enough play to push it further in and then wiggle it out. Might take a bit of deft handedness but it does come (or at least does on mine).
Cheers.
Offline cняis
« Reply #3 on: 15 November 2010, 21:02 »
my lights were stuck fast in the brackets, brackets needed to come off complete as it was easier  :grin:
Offline mboon
« Reply #4 on: 15 November 2010, 21:29 »
Going to have ago at this at the weekend
 thanks lads
