Author Topic: what gearbox is in my mk2 gti 8v urgent  (Read 10505 times)
Offline messenjah
« on: 12 November 2010, 16:36 »
hi guys my gearbox decided to sh!t itself today ive pciked up fragments of gearbox casing and some shaft and one gear  ... from the road
i need a new gearbox but i neeed to know what one it is so i make sure i buy the right one
Offline messenjah
Re: what gearbox is in my mk2 gti 8v urgent
« Reply #1 on: 12 November 2010, 16:44 »
its a 5 speed   but i cant read the code ont he sticker in the boot is it written anywhere else other then the bottom of the gearbox itself ?
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 12 November 2010, 16:50 »
020 Gearbox codes:
1.ACD
2.AUG
Offline messenjah
« Reply #3 on: 12 November 2010, 16:52 »
so i need an aug or acd gearbox then ?
Offline messenjah
« Reply #4 on: 12 November 2010, 16:55 »
i also dont mind doing an upgrade at the same time but i need to have it all back together by tuesday ...
« Reply #5 on: 12 November 2010, 16:55 »
What year is your car and is it digifant or k-jet.
Offline messenjah
« Reply #6 on: 12 November 2010, 16:58 »
1992 on a j  and its digi
« Reply #7 on: 12 November 2010, 17:02 »
AUG box was fitted from 1989 onward, so you have one of these.
Go here for more in depth knowledge.
http://www.brokevw.com/
Offline messenjah
« Reply #8 on: 12 November 2010, 17:22 »
looking at that its deffo the diff thats f**ked and probably due to rivet failure  because that is described on there as the weak point on the transmission
Offline tony_ack
« Reply #9 on: 12 November 2010, 18:19 »
Definitely an AUG, and the later models also had a shorter second gear that allow you to reach 62 in 2nd.
Diffs are the weak point on the boxes - I had to swap mine as it was on the verge of giving up. It might be an idea to install a bolt kit on the new one and replace the dodgy rivets.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
