Author Topic: 13.75 volts  (Read 1805 times)
Offline mr burns
13.75 volts
« on: 11 November 2010, 18:13 »
Checked my alternator voltage output today on tickover it was 13.75 volts is that ok to be recharging the battery as had a few probs with my battery as late ( it's only 8 mths old)
thanks in advance
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 13.75 volts
« Reply #1 on: 11 November 2010, 18:24 »
I have had same issue yesterday & had to get GSF to give me a new battery as the last one failed to start the car in the morning... and was only just 12 months old....
Did want to upgrade to a Bosch but they wouldn't ave it.... I've had it with GSF branded goods now - this is the 3rd battery in 12 months as my Audi one also failed...
Anywhere between 12.9 & 14.5 Volt on tickover should be fine to charge it AFAIK...
For More Info Click To See;
Offline mr burns
Re: 13.75 volts
« Reply #2 on: 11 November 2010, 21:00 »
I know what you mean this is my second GSF battery not that impressed  :angry:
Re: 13.75 volts
« Reply #3 on: 11 November 2010, 23:23 »
Sounds a bit high  :undecided:
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 13.75 volts
« Reply #4 on: 11 November 2010, 23:35 »
Offline Simeon
Re: 13.75 volts
« Reply #5 on: 12 November 2010, 15:44 »
All cheap end lead acid batteries are the same with different stickers on, if you don't want to be swapping batteries every couple of years (or less) then fork out £150+ on a proper one and just swap it between your cars if you buy/sell a lot
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 13.75 volts
« Reply #6 on: 12 November 2010, 16:25 »
Valid point - BUT when the sellers gives a 3 Year warranty with it - Its fair to expect that its good for "at least" that amount of time...
Off to Halfrauds with my Trade card next time!!
« Last Edit: 12 November 2010, 16:46 by X4MGS »
Offline The Mighty Elvi
  • I'm better than you today.
Re: 13.75 volts
« Reply #7 on: 12 November 2010, 16:44 »
As I write my GSF battery is on the charger in the kitchen.  Ironically it failed on me in the GSF car park in Swansea.  They had to bump start me.  :grin:
Agree that batteries should be expected to last the length of the warranty.  Mine has given up the ghost becuase I left the golf standing for 8 months and it went flat.
So I may plump for the one that Khare bought.
http://www.advancedbatterysupplies.co.uk/carbattery075.html
