Author Topic: 3 door seat cable come off...  (Read 983 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 11 November 2010, 13:34 »
As far as I can tell, the cable that moves when you pull the latch on the side of the front seats to make the top half go forward, has come away from the mech. If I pull the lever, nothing happens. Where do I start in taking it apart to get it back together??
Re: 3 door seat cable come off...
« Reply #1 on: 11 November 2010, 14:22 »
could be cable has snapped common fault. start by removing the plastic trims either side, 3 pins you need to push thu to release. then theres a circlip both sides, pop off and pull legs apart and backrest comes off. then its a case of undoing clips and piegs etc till you can peel the fabric up enough to get to the cables
Offline X4MGS
  • VAG Parts SNOB!!!
For More Info Click To See;
