Author Topic: When my blowers are on...  (Read 3948 times)
Offline mwep201081
Re: When my blowers are on...
« Reply #11 on: 10 November 2010, 22:35 »
He said he won't buy new lad  :rolleyes:
Yeha and I'm imparting some advise (what forums are generally used for) to buy a new one....Not a ropey 19 year old one that's probably no better than the one he's got! :rolleyes: lad.
Offline Sam
  • Sam I am
« Reply #12 on: 10 November 2010, 23:04 »
Well, I know how to take it out now so will do it tommorow at some point and try get some WD in
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #13 on: 10 November 2010, 23:08 »
Don't forget to check the condition of the seal between the scuttle tray and the fresh air blower mesh cover.
If this has perished water can get into the blower.
Remover the blower cover and put a bead of silicone selant around the base. Refit and this will prevent water going into the motor.
Offline mwep201081
« Reply #14 on: 10 November 2010, 23:09 »
I'd try spray on lube...WD will dry it out and probably make it worse.
Offline Sam
  • Sam I am
« Reply #15 on: 10 November 2010, 23:13 »
Spray lube you say? Will try get hold of some, or will normal grease do?
Offline moby dick
\\\"I spent a lot of money on booze, birds and fast cars. The rest I just squandered\\\" George Best
« Reply #17 on: 11 November 2010, 10:06 »
silicone spray lube is what i use for this. wd40 isnt a lube its a water dispersant ;)
if you can persuade the plastic fan housing to come off it'll make it much easier to get to the bearings to clean and inspect. i tried on mine and gave up in the end, just got a goodun from a mk2 in scrapper. try to find a random car with a battery still in it so you can test it first!
Offline Sam
  • Sam I am
« Reply #18 on: 13 November 2010, 12:30 »
5 Min fix: Take it off (30 seconds) un-clip the electrical terminal that lets you inside and nuke it with some wd (tried spray lube but wouldn't work) then shake it a bit, clean off excess wd then wack it back in. Bish bash bosh.
So, whats easier to do then? Go on ebay and buy a new one  :huh:
Offline bodga
  • F reg GTI 16v
« Reply #19 on: 13 November 2010, 16:09 »
 WD wont last long, i tried it.  :sad: i used my dipstick to put some engine oil on the bushes. oil will soak in, WD dries it up. it was this time last year when i done it so it lasted longer than my other bodges
