Author Topic: MPG problems for the past year  (Read 17434 times)
Offline Agreeable Slick
  • Unit
Re: MPG problems for the past year
« Reply #10 on: 10 November 2010, 17:53 »
Might be temp sender related. Seems silly, but they can affect mpg. Might be worth chucking a new one of them in? £30 ish.
EGR wouldn't really effect it, as it's an emissions addition. Will drop mpg by a few points, but not by this much.
Offline richandhazel
« Reply #11 on: 10 November 2010, 20:10 »
Timing might well be worth a look. I set mine at around 70 on VAGCOM and I can usually get at least 500 miles on a tank full.
Best was just over 600 but when I did that it was just running to and from work (M3 & M25) and all the roadworks were going on so 50mph most of the way!
Be interesting to know what your timing is set at :undecided:
« Reply #12 on: 10 November 2010, 20:12 »
Should have mentioned........that's a 1999 110BHP, AHF engine.
Offline asif
« Reply #13 on: 10 November 2010, 22:13 »
Has the timing belt ever been changed? timing could be slightly out, but i would expect performance to suffer.
All diesels seem to suffer from clogged up EGR valves, worth a look?
Timing belt has been changed at about 57k now on 80k, performance isn;t too bad but does feel a bit slower on pick up after the intercooler which I was surprised as I thought it'd spool up the turbo much faster?
MK7 GT Bluemotion Tech TDi 150
Offline asif
« Reply #14 on: 10 November 2010, 22:14 »
EGR has been mapped out and when the mech checked he said it's not bad as he's seen in the past so won't be the EGR
Offline AudiA8Quattro
« Reply #15 on: 10 November 2010, 22:15 »
I read that EGR valves can cause quite significant running problems. It can affect the air flow readings, or so the article said.
I can't really say for sure, as i'm not really into diesels.
« Reply #16 on: 10 November 2010, 22:16 »
Maybe worth re-checking the timing?
Offline asif
« Reply #17 on: 10 November 2010, 22:17 »
Not sure about the timing, are there any other symptoms if the timing was out?
When I start the car from coldfirst thing in the morning it sort of hesitates a bit for about 20 30 seconds like it aint got enough revs and chucks out a cloud of smoke not coloured just like white kinda exhaust smoke as normal then stops straight away.
It's the hesitation that gets me worried kinda like the car can't breathe kinda thing (best way I could explain it :grin: )
Offline asif
« Reply #18 on: 10 November 2010, 22:19 »
EGR is mapped out so not in use and the mech said the EG isn't that dirty anyway so hopefully not restricted at all.
« Reply #19 on: 11 November 2010, 00:06 »
I mapped out my EGR too, one of the first jobs I did after cleaning out the intake!
Have you easy access to VAGCOM, it's a very quick and easy check to see where your timing is :wink:
