Poll
Im just wondering what injectors would be best to use?
green
1 (100%)
grey/blue
0 (0%)
Total Members Voted: 1
Author Topic: Mk2 2.0l 8v Project  (Read 2276 times)
Offline rossbarry1
Mk2 2.0l 8v Project
« on: 10 November 2010, 07:36 »
I have the green injectors from the 2.0l mk3 engine or the standard grey i think from my 1.8 digi. I would assume i use the green ones. Im currently building up the new engine, 2e block and 1.8 stage 3 pb head, i will also be putting on a 4-1 manifold and a stainless exhaust system (when i find some money). Anyone got any other ideas of what i could do to improve?
Thanks
Re: Mk2 2.0l 8v Project
« Reply #1 on: 10 November 2010, 09:19 »
2e and mk2 digi injectors are completely different shape so you have to use the mk2 ones regardless. whats the bosch number on em i can check flow rates for you?  i used some vaux 'cream' ones from a 2.0, slightly uprated over 1.8 digi ones but not so much that they would flood the engine. with the co tweaked it seemed to go pretty well :)
« Reply #2 on: 10 November 2010, 10:06 »
What cam are you planning on running.
Offline rossbarry1
« Reply #3 on: 10 November 2010, 10:11 »
I was planning on using my existing 1.8 pb cam, unless using the 2.0l cam will show improvement?
Offline rossbarry1
« Reply #4 on: 10 November 2010, 10:34 »
bosch part number is 0280150902. Thanks
« Reply #5 on: 10 November 2010, 10:48 »
To be honest if the stage 3 head has bigger valves (which it should do) then you would be better to run a 272 or 285 profile to get the best out of it.
Also would be worth looking at a remap.
Offline rossbarry1
« Reply #6 on: 10 November 2010, 10:52 »
remap or chip? running on a bit of a budget at the moment was looking to change the cams at a later date. which is best to use in the mean time?
« Reply #7 on: 10 November 2010, 10:53 »
Remap would be better, use the pb cam as a short term option.
