Author Topic: audi 2.2 throttle body..  (Read 1990 times)
Offline harr1s
  • mk1 caddy and mk2 gti owner
« on: 03 June 2003, 23:01 »
   hello there chaps, Im sure that ive seen it about on the forum somewhere? about the audi  2.2 throttle body fitting on a mk2 as a direct replacment also something about the warm up valve/ regulator.  has anyone carried out this mod or know anymore about it and what difference to performance would it make or would it cause any long term problems. also which audi model is it exactly..
   please help ....
            cheers.......
                              Harr1s.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
old_boy
Re: audi 2.2 throttle body..
« Reply #1 on: 03 June 2003, 23:31 »
I did it on an old mk1 gti, you can use any bigger throttle body, but i was told to use the matching warn up reg from the same donor engine.
The inlet manifold has to be opened up so the ports match.
A vacuum hose needs to be connected to the warm up reg so the fuel is enriched on full bore.
Drill your air box and get a K&N-you will really notice the difference! ;)
Any further help needed-get in touch
Offline richandhazel
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline tattoomang60
  • smell the fear!!
« Reply #3 on: 19 May 2011, 12:02 »
i done it on one of my mk1s and it realy dose make a diff. :laugh:
keep pushing the limits!!!
Offline rossbarry1
« Reply #4 on: 19 May 2011, 21:49 »
i thought the mk2 TB were the same size and it makes no diffrence
