Author Topic: Mk3 Gti Running issues (yeah, mine too!)  (Read 4372 times)
Offline watercool
Re: Mk3 Gti Running issues (yeah, mine too!)
« Reply #30 on: 25 November 2010, 18:59 »
Ok cleaned it again but did a much better job, now it runs even better! Still a bit of hesitation but I'm going to give it a full service, including leads/dizzy/rotor arm and see how it is after that. Also need to change the gear box oil as getting it in to first and second is NOT smooth.
Offline javalin
« Reply #31 on: 26 November 2010, 12:21 »
yup deffo - its a must on the mk3's!!  Can recommend the Bosch Super plus quad electrode ones - probably not much difference to other decent plugs, but some are really poor.  I think its these I put in my AGG (look up the correct ones for yours) - http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_170523_langId_-1_categoryId_165736
good plan.  Also check that the engine mount behind the gearbox isn't dead - you might see oil arround it if its dying.  Mine was and the gearbox/clutch is much more consistent to use now.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
