Author Topic: revs  (Read 1183 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
revs
« on: 06 February 2005, 19:05 »
after i was drivin about today i noticed my revs were not droppin they were on nearly 2000 i noticed a few times now and i dont know what the cause of it is i was thinkin maybe the clutch was stickin but it drives fine
any ideas?
cheers
Re: revs
« Reply #1 on: 07 February 2005, 11:57 »
What car is it?  If its a carbed model then most likely an autochoke fault, check it gets 12v when cold.  Next thing to check is the coolant channel o'ring in the inlet manifold, it can degrade over time and block the flow of coolant, a common fault on carb models.
When the engine is up to temp the autochoke unit should be very hot, almost too hot to touch!
Offline VR6_ROB
Re: revs
« Reply #2 on: 07 February 2005, 21:03 »
its 1990 injection pb engine if that helps digifant
Re: revs
« Reply #3 on: 08 February 2005, 12:58 »
Dunno about that then, could be the ISV or a vacuum leak?
Offline VR6_ROB
Re: revs
« Reply #4 on: 09 February 2005, 18:20 »
right problem number 2 revs seem to of dissapeared gears are becomin knotchy although i hav a driveshaft leak the oil might of gone as i hav not topped it up yet and also when i accelerate they is a whistlein noise but this has been goin on for ages
