Author Topic: Engine won't start. 16V MK2  (Read 1024 times)
Offline alex2504
« on: 06 February 2005, 17:24 »
The cylinder head gasket had gone an my Golf, have replaced with new gasket and tidied up the head a bit. Its now all back together again but I cannot get the engine to start. Have tried following:
- There is plenty of spark
- All the Vacuum hoses seem to be back on the correct locations, but not a 100% sure
- When i remove an injector from the head there doesn't seem to be any fuel injecting through it, should there be?
- Positive pressure in the Inlet manifold when I remove Injector, is this normal?
- The fuel pump works no problem, when I push up the plate in the airbox while trying to start there is fuel going through the injectors.
When i try to start it there is absolutely no life in the engine
Can anyone help?????? Before I go mad!!!!!
Alex
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re: Engine won't start. 16V MK2
« Reply #1 on: 06 February 2005, 17:44 »
check tred (16v won't start)below as theses guys gave me a push in the right direction!
wacked up on scuby snacks!
