The garage
heater problems
Topic: heater problems (Read 31034 times)
moffatt1990
heater problems
08 November 2010, 18:59 »
hi i have a 1.8 mk3 golf driver my heaters are not blowing hot i have been told to check the heater controle valve but i cant find anything that resembles one can anybody help me locate it or have any other ideas of the problem im prity sure its not the thermostat as car gets to temp fine and dose not over heat i have bled the system so its not a clog
Wayne
Sir Postalot
Re: heater problems
09 November 2010, 09:08 »
Air lock or blocked matrix I would guess
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: heater problems
09 November 2010, 12:16 »
no heater control valve on a mk3, coolant passes thru matrix at all times. check coolant level as a first step. does the heater knob feel liek it has resistance behind it and/or can you hear the flap move inside the airbox
moffatt1990
Re: heater problems
14 November 2010, 14:19 »
coolant level is fine no airlock or blockage as ts been flushed and es the nob dost have resistance and can hear it there is a verry slight difrance in temp aswel
rubjonny
10k hero
Re: heater problems
15 November 2010, 11:52 »
sounds liek you need another matrix, its possible the warm air flap has broken down as well, over time the foam falls off and you're left with a metal flap with 3 big holes in it
moffatt1990
Re: heater problems
18 November 2010, 12:43 »
thanks for your help i have had bits of foam come from the blowers is the flap easy to get to ?
rubjonny
10k hero
Re: heater problems
Reply #6 on:
18 November 2010, 13:24 »
takes the same amount of work as a heater matrix swap unfortunatly
moffatt1990
Re: heater problems
Reply #7 on:
18 November 2010, 18:27 »
i have just removed my heater matrix the flap is fine and the matrix is fine to the best of my knolage (how would i know its not working) iv atached it to a house tap and water flows threw fine it heats up a lil (i asume only a little as it was a house tap ) im stumped an dot want to put the dash back in to find it is the matrix
rubjonny
10k hero
Re: heater problems
Reply #8 on:
19 November 2010, 10:28 »
matrix could still be partially clogged, best to buy a new one anyway while its all apart. if that still doesnt help then its gotta be waterpump or stat fault?
http://www.golfgtiforum.co.uk/index.php?topic=106380.0
The garage
heater problems
