Author Topic: Is this an alternator issue?  (Read 1251 times)
Offline JimR
« on: 08 November 2010, 17:47 »
Driving home from work tonight, had the wipers on normal, headlights on (not main beam) but as i was accelerating out of a slip road up to 60 light light under the battery symbol started glowing dimly, i realise this is alternator related but could it be a slipping belt causing it or is it new alternator time?
Thanks in advance
James
Mk2 GTi.
Offline theclash
Re: Is this an alternator issue?
« Reply #1 on: 08 November 2010, 17:54 »
try adjusting the belt first see if it helps
Offline clipperjay
« Reply #2 on: 08 November 2010, 17:57 »
Buy a cheap multi meter stick it on the positive and negative terminals comming of the alternator, check if its over 14.4V if anything less than 12V its needs a refurb or an exchange.
Offline JimR
« Reply #3 on: 08 November 2010, 18:09 »
Cheers for suggestions, i have a multimeter, I'll check a bit later, adjusting the belt is a bit of a bind as the 'star' wheel is mashed, aluminium pinion on a steel rack was never a good idea.
Mk2 GTi.
Offline Dolly
« Reply #4 on: 08 November 2010, 18:50 »
Dont know where in the uk you are, but here in the midlands its rained all day, the belt used to slip on my old driver everytime i splashed through a puddle, a new belt and abit more tension sorted it.
