Detailing
Wheel Sealant?
Topic: Wheel Sealant? (Read 14858 times)
--jp
Wheel Sealant?
07 November 2010, 18:24 »
What are you guys using? i'm not using anything at the moment and want to do my RS's before winter hits, although it seems to be here already!
richw911
10k hero
The Linkmeister and an OEM Freak.
Re: Wheel Sealant?
07 November 2010, 18:30 »
I use Poorboy's - its spot on
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=148&idcategory=82
--jp
Re: Wheel Sealant?
07 November 2010, 18:33 »
cheers for that Rich, do you use anything else on them or just polished up and then waxed?
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Wheel Sealant?
07 November 2010, 18:39 »
you can use jetseal 109 i believe aswell and its an alrounder on paint work too..
Mk4 Golf GTI anniversary and mk6 golf tdi
richw911
10k hero
Re: Wheel Sealant?
07 November 2010, 18:40 »
Quote from: --jp on 07 November 2010, 18:33
I just wash then use SRP and finish with two coats of Poorboy's sealant
Im sure the experts will tell you a better way and products though
--jp
Re: Wheel Sealant?
07 November 2010, 18:43 »
yep, I was going to do the same as the rest of the car except with the wheel wax instead of the normal wax
tech1889
Mk2 GTI FTW !!
Re: Wheel Sealant?
Reply #6 on:
07 November 2010, 19:25 »
you can seal with jetseal 109 and then if you want to get extra glossy get some high temp wax as others wont last with the heat..
SI74
Re: Wheel Sealant?
Reply #7 on:
07 November 2010, 21:19 »
FK1000p high temp wax. Best stuff ive used
waxamomo
Forum Supporter
Re: Wheel Sealant?
Reply #8 on:
07 November 2010, 21:40 »
You are right in now wanting to use a normal wax, they are not made to deal with the high temperatures and wont last 5 minutes. Anything like Poorboy's Wheel Sealant, Jetseal 109, or FK1000p will do a great job
New Website, New Manufacturers, New Rewards
5% off with Discount code -
ilovewaxamomo
Dan J
Pro Valeting and correcting paint since 95
Re: Wheel Sealant?
Reply #9 on:
07 November 2010, 21:41 »
collinite 845 or fk1000p layered.
Detailing
Wheel Sealant?
