Author Topic: Fitting new rear parcel shelf support  (Read 1966 times)
Offline moby dick
« on: 07 November 2010, 15:16 »
I have picked up a replacement rear parcel shelf support but I'm not sure how to remove and refit the rear seat belt. Any advice warmly welcomed.
\\\"I spent a lot of money on booze, birds and fast cars. The rest I just squandered\\\" George Best
Offline clipperjay
Re: Fitting new rear parcel shelf support
« Reply #1 on: 07 November 2010, 15:59 »
If you mean the shelf with to straps its simple pull towards you the two supports will pull free no seatbelt needs removing. If you mean the two speaker shelves then you need to remove three bolts. One under the shelf one at the top and last near the seat base.
Just remember to torq up the bolts well its a seatbelt at the end of the day
Offline dubber36
« Reply #2 on: 08 November 2010, 07:52 »
Another tip, before you undo the bolt that holds the reel on, pull the belt out fully and put a clamp on it to stop it winding back in. Mole grips and a rag will do.
The belt will only pull out of the reel when it is set at the angle it is fitted into the car at. Having plenty of slack makes it easier to re-fit.
« Reply #3 on: 08 November 2010, 09:56 »
dont need to undo the belt reel from car, just the bolt right at other end next to seat base and the one holding it to the c pillar. belt pulls thru the shelf support, swap over and bolt back together
Offline clipperjay
« Reply #4 on: 08 November 2010, 10:11 »
I had to because the bloody seat belt would not free up enough so I took all three off to get the whole thing loose enough to correct it.  :grin:
Offline moby dick
« Reply #5 on: 08 November 2010, 14:28 »
Guys Thanks for the guidance
Offline moby dick
« Reply #6 on: 09 November 2010, 12:19 »
Mission accomplished, thanks
