Author Topic: water in car??  (Read 2067 times)
Offline GTI-JAY
water in car??
« on: 07 November 2010, 14:51 »
anybody know why i have got water in the drivers footwell and the rear driver side footwell, seems it only happens when it rains overnight? any help would be much appreciated  :smiley:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: water in car??
« Reply #1 on: 07 November 2010, 15:12 »
prob blocked drainage holes on sunroof, these are on each corner of the sunroof, they exit in the door hinge area, you will see some blsck tube things poking out, use a bit of wire and feed it down
if you used search function this has been covered many times
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline j8k vw
Re: water in car??
« Reply #2 on: 07 November 2010, 19:06 »
Hello,
You might want to check your scuttle panel. It seals against the windscreen and they rot quite commonly. Jak.
Offline Deano2711
  • 1992 VR6
Re: water in car??
« Reply #3 on: 07 November 2010, 19:09 »
Also has drainage holes in the corners of the wings by the scuttle panel. These get clogged up with leaves easily this time of year. At worst could also be the heater matrix but check all the drainage holes first though Mate.
Offline Walkerboy
Re: water in car??
« Reply #4 on: 07 November 2010, 19:15 »
scuttle panel usually means it leaks in the passenger footwell dude as it leaks through the pollen filter
im with f17bad or it might be leaking through the door skin(this is if the door glass has been replaced)
the drainage channels r in 2 sections,bottom is rubber j pipe and then youve got the actual pipe.might need you to unblock the rubber j piece by gettin abit of wire and se how much mud ect comes out then open your sunroof slightly and run hot water off of the glass,if it comes out the rubber pipe then cool.lol
if not then it might be where the two pieces join.
i had this and had to try and get the rubber out and clean it properly
Offline Deano2711
  • 1992 VR6
Re: water in car??
« Reply #5 on: 07 November 2010, 19:18 »
The drainae holes under the scuttle panel can let water in either side as the water runs down the inside of either win and can et in through either the door or the footwell. I had this problem on my old Mark 3 drivers side.
Offline dubnutt 69
Re: water in car??
« Reply #6 on: 06 March 2011, 19:33 »
hi ppz...i jus got a mk3 golf an it leaks a lot in the passenger side in from unda the dash...noticed it wen got it went thru the nut ache of replacing matrix then took it for a jet wash.....pissd a load thru the dash on passenger side str8 afta.....help? i noticed wen dash was out thet the foan around the heater blower fan has perished....cud this b the problem?? thanx :cry:
Offline neil1780
Re: water in car??
« Reply #7 on: 06 March 2011, 19:54 »
Its prob the pollon filter tray it's under the scuttle panel on passengers side.
V6 4MOTION
Re: water in car??
« Reply #8 on: 06 March 2011, 20:54 »
Check around the pollen filter to see if it fitted down all ok, also check that the drains are clear.
