Author Topic: Help needed to bypass this F**king Conlog logic 900 crap  (Read 7244 times)
Offline marky-gee
Righty hoe !!
Im right up to here`````` with this crappy conlog logic 900 alarm . im reading there is a method to bypass the thing but obviously its not common knowledge for security reasons, So if somebody with hte knowhow could PM me it i would be most greatfull.
I really don't think my hair can stand anymore abuse so act now if you can help
thanks
BTW car is a mk3 gti if thats any help.
1997 GOLF GTI 2.0 (8v)
Re: Help needed to bypass this F**king Conlog logic 900 crap
« Reply #1 on: 08 November 2010, 10:13 »
if its aftermarket, find the brain, follow the wires from it and chop out where they connect to your loom. join together any wires that have been cut into matching wire colours.  if its factory, should find 2 pin plugs which can be removed then you find late spec mk3 without alarm, nick the 2 pin plug joiners and fit to your loom to rejoin.  2 that come to mind are yel/blue for fuel pump relay trigger and red/black for starter.
Offline marky-gee
« Reply #2 on: 08 November 2010, 16:31 »
Anyone got any ideas if this will have any affect on the STD immobiliser(ie, the little chip.in the key?)
« Reply #3 on: 09 November 2010, 12:14 »
no it shouldnt do, just make sure you dont cut any wires to the immob box. follow the wires from the reader coil on ign lock and you'll find it
Offline marky-gee
« Reply #4 on: 09 November 2010, 20:28 »
Thanks that handy info, so if I'm careful and reconnect any wires that have Been cut and routed elsewhere I should be ok.
Just looking for some reassurance that if I strip it out the i can still get to work on monday, and wont need recoding for any reason.
So to recap
1. Trace wires and remove rejoing any original ones back to standard.
2. The chip in the key should still work even thought the conlog is gone.
3.
« Reply #5 on: 10 November 2010, 09:17 »
1. yep
2. aye
3.
mk3s are common in scrappies now too, so once get car sorted can go on the hunt for unbutchered cars and nick all the stalk/ign switch looms and swap tyo yours. the fusebox in the mk3 is great all the looms are seperate so dead easy to swap different bits of it :)
Offline marky-gee
« Reply #6 on: 14 November 2010, 23:39 »
These colours look to be right after ripping it out today. I just can't find the other ends now ???
« Reply #7 on: 15 November 2010, 11:58 »
do you mean you have found a pair of 2 pin plugs, with red/black and blue/yel wires? if so, you need to find a later mk3 without an alarm fitted and pinch the 2 jumper plugs which pop into these 2 pin plugs and rejoin the wires. or chop plugs off and splice the wires together
