Author Topic: Have Halfords sold me the wrong battery?  (Read 4492 times)
Offline HuwMk2
« on: 06 November 2010, 19:07 »
My old battery recently died, I was in a hurry so bought a new one from Halfords. The old battery was a 075 but the Halfords guide book and sales merchant said I needed a smaller 063 battery. However, since fitting the new battery the car does not start on the first turn of the key as it used to, I presume this is down to the new battery being too small. My car is a 1992 8v. Is the new battery incorrect??? Thanks.
Offline Bigdunc
Re: Have Halfords sold me the wrong battery?
« Reply #1 on: 06 November 2010, 20:08 »
i think i got a bosch 063 in my car atm, it seamed ok untill i installed a sub, now im debating weather to swap it for a 075
« Last Edit: 06 November 2010, 20:32 by Bigdunc »
Offline cняis
« Reply #2 on: 06 November 2010, 23:26 »
063 should be fine! 075 can be used as an upgrade but my 2.8 vr6 only uses an 075.
Offline AlexMozza
« Reply #3 on: 06 November 2010, 23:29 »
As long as it has the correct CCA it should be fine :)
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 07 November 2010, 10:05 »
Buying any car battery from Halfords is the wrong battery :rolleyes:
Thom
Offline cняis
« Reply #5 on: 07 November 2010, 10:30 »
Thom
also about 50% more expensive than anywhere else.
suckers!
Offline clipperjay
« Reply #6 on: 07 November 2010, 16:15 »
Everyone is saying this and that about battery but have you considered that your alternator might be fecked? Hence no matter how big or expensive your battery it will go flat anyways?
Mines a 063 and its fine. Unless you have a diesel or funky glow plugs you don't need that much cranking power.
Get a volt meter and check what your drain is on your terminals at the alternator and battery!
Or your starter motor is on its way out?
« Reply #7 on: 07 November 2010, 16:53 »
063 will be fine as Jay said you might have another problem
Offline vr6 south
« Reply #8 on: 08 November 2010, 12:52 »
Thom
suckers!
Probably the cheapest if you have a trade card :rolleyes:
Offline danny_p
« Reply #9 on: 09 November 2010, 00:46 »
battery size has littel to do with starting the car.  i have a rinky dinky 14 AH to go on mine.   dinky size, light, radio would flaten it in about 10 mins but gives 600 CCA
all the VW's have gone bar 1.
