Author Topic: Engine coolant  (Read 1716 times)
Offline emery1990
Engine coolant
« on: 06 November 2010, 13:54 »
Is the likes of g12 coolant just normal anti freeze ? Is it oil based, reason I ask is because when filling up solar panels with glycol which is antifreeze, ive always got some left and need to fill up my coolant, so could I just use this, as its its just anti freeze. Or is g12 and other anti freeze products made more engines ? This is stuff is like £1 a litre rather than the £12 /l of g12!
Offline tech1889
  • Mk2 GTI FTW !!
Re: Engine coolant
« Reply #1 on: 06 November 2010, 17:56 »
tps is £6/litre of g12++ i believe and as far as im told its a much better anitfreeze for the engine..
Offline emery1990
Re: Engine coolant
« Reply #2 on: 06 November 2010, 23:38 »
ermmm, still not convinced, id be more worried about the water pump than the engine, as the engine is a big lump of metal.
Re: Engine coolant
« Reply #3 on: 08 November 2010, 10:15 »
nothing special about it really, most antifreeze will do same job. just a case of dont match incompatible types, mix g11 blue and g12 red and it turns to brown sluge. G12+ and ++ purple are formulated to mix with both.  if you want i can piccy the back of a bottle so you know whats in em. main thing is car antifreeze has anti-corrosion inhibitors in em, your special panel stuff may not.  car engines use a mix of metals where your panels might be all the same stuff in the coolant channels
Offline emery1990
Re: Engine coolant
« Reply #4 on: 08 November 2010, 18:29 »
Yer this stuff is just  plain old glycol, its cooper and stainless steel.
Just would of been handy as its like £1 a litre!
Ill just get the proper stuff lol
Offline pluslyn
Re: Engine coolant
« Reply #5 on: 09 November 2010, 18:26 »
I use Comma Xstream Red Longlife Antifreeze. (Audi/Seat/Skoda/VW), MB(325.3), MAN(324-SNF)
Pure Concentrate Ethylene glycol, silicate free with organic acid. For petrol & diesel engines Longlife 5 year Protection.
www.commaoil.com
« Last Edit: 09 November 2010, 20:47 by pluslyn »
