Author Topic: Vag com software  (Read 1792 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
Vag com software
« on: 05 November 2010, 23:06 »
Hi all,Im in need of the software to run diagnostics on a few vw and audi's.I had a scanner before and it was ok but very basic.
What have you guys used and can recommend???
Re: Vag com software
« Reply #1 on: 08 November 2010, 09:15 »
its just called vag-com, you need the £10 cable off ebay and software version 409.1
Offline garethcab
« Reply #2 on: 11 November 2010, 22:44 »
Free one is fine for basic checking of modules and clearing individual codes as long as it's not some of the newer vag models. Post 2004 ish, they used can-bus which the free item wont read.
The free one is fine on my 1995 golf and ok for 85% of the modules on my 2003 RS6, but it won't read my 2005 vw touran.
I have now purchased a proper one from Ross-tech.
Offline thebassman
« Reply #3 on: 12 November 2010, 13:35 »
Are there any cables to avoid off ebay, i have read on here about some not working?
Also do you just download from these guys ?
http://www.ross-tech.com/vag-com/vag-functions.html
cheers
« Reply #4 on: 12 November 2010, 14:25 »
they're all much of a muchness really. main thing is to make sure your OS is supported by the cable. rosstech only have vcds lite, which does work with cheapo cables usually but i only have a 'modification' for 409.1 if you know what i mean
Offline whit
« Reply #5 on: 21 November 2010, 20:02 »
i would say avoid a cable with serial connector (using a serial to USB adaptor)  because thats what :sick: i got and it refuses to work whatever i try!!!! :(
