Author Topic: Problems with my TDI :( Another problem !!  (Read 6781 times)
Offline asif
Re: Problems with my TDI :(
« Reply #10 on: 05 November 2010, 18:37 »
Judging by comments on other threads the silicone pipes aint that great apparently?
MK7 GT Bluemotion Tech TDi 150
Offline Ady TDI
« Reply #11 on: 08 November 2010, 09:16 »
Got under the car yesterday, removed the under tray, then i noticed that the hose next to the rad and ac hose had popped out, pushed it back in but it came out again, i'm hoping it is just the clip and not a problem further down the line which is causing it to pop out
Offline Kerrse
« Reply #12 on: 08 November 2010, 10:00 »
May be lug wear, i am replacing the very same pipe ( i think) , worth trying a clip change first though before buying a new pipe.
Offline Ady TDI
« Reply #13 on: 08 November 2010, 10:33 »
Thanks kerrse, can you buy just the clips and from where apart from VW as there isn't one local to me, maybe GSF sell them ?
Offline Kerrse
« Reply #14 on: 08 November 2010, 10:39 »
I think you may have to go to VW but you could maybe buy online ? there are 2 different size clips so make sure you get the right ones, although i did manage to fit a smaller clip on that pipe as thats all i had.
Offline Ady TDI
« Reply #15 on: 08 November 2010, 13:55 »
Thanks again mate, is there a special tool that is require for the clips or will pliers be sufficient ?
Offline Kerrse
« Reply #16 on: 08 November 2010, 14:48 »
The special tool, know as a screwdriver :) they are fairly easy to get on & off which is probably half the problem with the stupid design half clips lol
Offline haf1zur
« Reply #17 on: 08 November 2010, 15:42 »
if it keeps popping off, then you need Mikalorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Offline asif
« Reply #18 on: 08 November 2010, 19:51 »
What's one of them bro?
