Author Topic: Steering - a little off...  (Read 2590 times)
Offline hmeah
« on: 05 November 2010, 09:58 »
My steering wheel is a little off track, the steering wheel is just slightly off when the car is going straight, is this something i can sort out myself? or do i need to take it into a garage or dealership?
Offline Rhyso
Re: Steering - a little off...
« Reply #1 on: 05 November 2010, 10:09 »
Sounds like your tracking is out
Take it somewhere which can do the full range of adjustment
http://www.alignmycar.co.uk/
 :smiley:
Offline Gene Hunt.
« Reply #2 on: 05 November 2010, 11:20 »
Mine was the same.Do as in post no 2 & that should sort it,it did for mine.  :wink:
Candy White ED35.
Offline Phil1980
« Reply #3 on: 05 November 2010, 11:47 »
Mine was like this tracking was out and bushes needed replacing, all sorted now.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline hmeah
« Reply #4 on: 05 November 2010, 11:57 »
thanks, my bushes were replaced about 6 months ago...
would someone like kwikfit do the tracking? or should i leave it till the next service at stealers? (anything now!)
Offline Rhyso
« Reply #5 on: 05 November 2010, 12:14 »
Take it to a place on the website I gave you the link for..............
Offline pluslyn
« Reply #6 on: 05 November 2010, 16:35 »
Best not to delay 'cause tyres might be scrubbing.
Offline GeeTeeI
« Reply #7 on: 05 November 2010, 17:34 »
I took mine for a full alignment yesterday.
The very best £120 I have ever spent on a car - and I've owned many and spent plenty.
It made the car feel brand new.
Amazing.
I only took it there because the steering wheel was 2' off centre, and the steering felt a little bit choppy.
Now it is perfect!
Yep, it isn't cheap, but is amazing.
The golf has a live rear axle, so it can be fully adjusted so it steers perfectly.
 :smiley:
Offline Stitch
« Reply #8 on: 05 November 2010, 19:18 »
Just check the tyre pressures aren't way off as that can cause the same issue.
Offline TrickGTI
« Reply #9 on: 05 November 2010, 20:18 »
Best to get it checked out and sorted. But just because the steering wheel isn't straight dosnt mean the tracking is out. Does it drive in a straight line without you haveing to keep it straight? I get alot of cars in for tracking issues when the steering wheel is not straight and it's because the front tyres are worn funny even though they look fine and if you swap them side to side the steering wheel is then out in the other direction and it's down to the tyres and no amount of setting up will get rid of that. Just a thought  :smiley:
