Author Topic: Which servo can I use on mk2 J reg driver?  (Read 1187 times)
Offline jayc
« on: 04 November 2010, 21:52 »
Hi guys, please can anyone help me, im stuck finding a brake servo for my mk2 driver.
Its the 90 spec type, a J reg 1.6 with a 2 port servo.
Can anyone tell me which, if any, replacement servos can I fit easily without too much modification?
Thanks guys!
jay
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: Which servo can I use on mk2 J reg driver?
« Reply #1 on: 05 November 2010, 23:05 »
I reckon a Mk2 GTI 8v, 90 spec item would bolt straight in. ( I have two if you're interested!  :smug:)
« Reply #2 on: 08 November 2010, 09:42 »
any mk2 one will fit. 1.0-1.6 is 7", 1.8 are 9".  9" obv an upgrade, but also more tricky to squeeze in. you can do it engine in though believe me, i managed on my mk2 gti 8v tho it was a struggle. you;'ll have much less hassle since its a carby, more room.
corrado and passat will also have the one you need, just make sure it has a clevis pin on the back not like a ball on the end of a pin (mk3 fitment)
