Author Topic: Rattle from the head on AUM engine  (Read 2495 times)
Offline sols
« on: 04 November 2010, 15:43 »
Hi, i'v recently bought a Mk4 golf GTI with the AUM engine, while the engine was idling the other day i noticed a rattling from underneath the rocker cover, i took the rocker cover off an noticed it has two plastic cam covers which i thought were rattling on the rockercover so i removed these but the noise is still there. The rattling also seems to come and go which led me to think it may be a blocked oil jet so i'v just flushed the engine, has anyone else had this problem or can anyone shead any light on what else could be causing this noise?????
Offline danny_p
Re: Rattle from the head on AUM engine
« Reply #1 on: 05 November 2010, 00:23 »
cam chain
all the VW's have gone bar 1.
Offline sols
« Reply #2 on: 05 November 2010, 13:54 »
just took the rockcover off an inspected the cam chain seems good
Offline ash1.8T
« Reply #3 on: 08 November 2010, 09:07 »
Could be timing chain tensioner does the sound go away when you blip the throttle?
Offline sols
« Reply #4 on: 09 November 2010, 18:23 »
The engine doesn't make the noise all the time but ye when it is it goes when you give it a little rev then comes back again, is the tensioner for the chain hydrolic??? cause when i had a look the other day it didn't look adjustable???
Offline ash1.8T
« Reply #5 on: 11 November 2010, 19:44 »
I think it's hydrolic not sure tho I've got the same noise on my car getting the tensioner change over the weekend
Offline new to vw
« Reply #6 on: 12 November 2010, 23:01 »
It sounds the same as mine bud.......Some muppet hadnt been servicing it properly.....mine turned out to be the oil pick up pipe in the sump....£8 from the stealers... (make sure you get the O ring as well):grin: :grin:
Get the car the car on a ramp or stands drop the sump and undo the 2 bolts that hold the pick up pipe on
Some of the bolts that hold the sump on are a pain in the butt to get out....You will need a set of allen keys and some RTV sealent.... :grin: :grin:
5 door 1.8t AUM
Offline sols
« Reply #7 on: 13 November 2010, 16:59 »
Thanks for the advice will get on to changing that oil pick up this week, let us know if you have any joy once you v had a look at the tensioner to mate mine seemed to be fine but if you notice anythin with yours could easily cheak mine to cure the rattle.
