Author Topic: Excessive Smoke GT TDi 150  (Read 10670 times)
Offline daron
« on: 04 November 2010, 15:35 »
Hello,
My first post and I have a query, sorry.
My lass had a problem one morning where the car wasn't starting, RAC came out and had a look, and mentioned the reason for this was because the little fella [see photos] was stuck.. once the little pin/lever was moved/freed, the car started.
Since then, she/we have noticed alot more black smoke from the exhaust whilst accelerating, and also poor... well I say poor 35mpg with very careful driving [normally 45+]
Is this all a result of a faulty part, if so.. what is it, Air Flow Meter?
Offline daron
Re: Excessive Smoke GT TDi 150
« Reply #1 on: 04 November 2010, 15:41 »
Doh, wrong place!
Offline Agreeable Slick
  • Unit
« Reply #2 on: 04 November 2010, 16:07 »
Looks a bit like a turbo actuator to me.
Offline josh_419
  • A hammer - The answer to everything
« Reply #3 on: 04 November 2010, 16:10 »
they have a spring on the actuator ? if im right ? that may of seized
GT TDI 130 - TT alloys, HID's, Lowered 35mm, ReMap (178bhp) + ridiculous torque. Build Thread
GTI 1.8 20v - For sale £2000
Offline Kerrse
« Reply #4 on: 04 November 2010, 16:19 »
Sounds more like boost leak ..check all todays posts on the subject
Offline Rhyso
« Reply #5 on: 04 November 2010, 16:24 »
The bit you've circled is the EGR valve / anti-shudder valve
Turbo actuator is situated further down under the car
« Last Edit: 04 November 2010, 16:26 by Rhyso »
  • Unit
« Reply #6 on: 04 November 2010, 16:26 »
Did wonder as never actually seen one of these engines in the flesh.
In that case, cheap and cheerful fix. Get a uprated one if possible, bit more pricey, but don't go wrong quite so easily.
Alternatively, take it off and give it a damn good clean.
Offline Rhyso
« Reply #7 on: 04 November 2010, 16:28 »
EGR is over £170 from VW  :angry: :cry: :cry:
EGR Delete pipe is what you need :afro:
http://cgi.ebay.co.uk/VW-GOLF-AUDI-SEAT-SKODA-EGR-DELETE-PIPE-PD-130-150-/160495031291?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item255e3fd3fb#ht_2438wt_1139
Or you can have the one that's sat in my shed  :grin: :grin:  Its off my 130 but it may fit the 150  :undecided:
  • Unit
« Reply #8 on: 04 November 2010, 16:32 »
:shocked:
PSI tuning in stoke have replacements for about £50 I think. :undecided:
Offline Rhyso
« Reply #9 on: 04 November 2010, 16:34 »
:shocked:
That will most likely be the delete pipe then which removes the valve entirely  :nerd:
And yeah I had to bite the bullet on the EGR as the pipe blew off and shattered the housing  :cry: :cry:
