Author Topic: Idle speed/carburetor problems!  (Read 2959 times)
Offline rizzel
« on: 04 November 2010, 13:47 »
I have an 1800 driver and have issues with it. Sometimes engine will be fine and will idle fine. Other times the engine speed will drop down to below 100rpm and sometime even cuts out. Also if I push the car a bit, it decides that it really doesn't like it and starts to sputter and jerk. If I turn it off and wait for about 20 mins, it then goes back to normal.
Any advice would be great, thanks :)
Offline mwep201081
Re: Idle speed/carburetor problems!
« Reply #1 on: 04 November 2010, 20:47 »
service it....plugs, plug leads, cap, arm, plugs , oil, filters etc
« Reply #2 on: 08 November 2010, 09:38 »
if its on the original 2e2 carb, have a read of my 2e2 repair guide. lots of info on the bits which can go wrong. or just admit defeat and buy a webber conversion ;)
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 08 November 2010, 14:20 »
Is that Jenson's strategy?
Seriously, you've been posting about Weber carbs for how long and you still can't spell WEBER?  :rolleyes:
Offline rizzel
« Reply #4 on: 08 November 2010, 16:40 »
how do I know if its the original 2e2 carb? not sure where to look  :laugh:
« Reply #5 on: 09 November 2010, 12:08 »
have a look in the 2e2 faq, if it looks like the pictures its a 2e2 ;)
2e2 is very complex bit of engineering, with vac pipes and electrical bits all over it. webber is very simple bit of kit
Offline rizzel
« Reply #6 on: 13 November 2010, 03:30 »
Any ideas how much the webber kit is and where I can get one from? Thanks
Offline rizzel
« Reply #7 on: 15 November 2010, 13:31 »
Hey, is this the correct one for my car? its an 1800 driver, J Reg
Thanks
http://www.fastroadcars.co.uk/shop/index.php?act=viewProd&productId=32
Offline mwep201081
« Reply #8 on: 15 November 2010, 15:30 »
Offline rizzel
« Reply #9 on: 16 November 2010, 01:25 »
Nice one thank you, hopefully this should sort the problems :)
