Author Topic: mk3 gti camber  (Read 1643 times)
Offline mysticman aka polypathetic
mk3 gti camber
« on: 04 February 2005, 23:05 »
does anyone know if the camber can be adjusted on a Mk3 as i am going to change the suspension on my car soon
i was wandering if when i change it will the camber affected by the changing process :undecided:
i know the front lower connection on the front has two bolts holding the suspension to the wish bone/swing arm, is there a small amount of play there that could cause a slight camber difference if not put back in exactly the same place as the originals
any ideas chaps
Offline AudiA8Quattro
Re: mk3 gti camber
« Reply #1 on: 05 February 2005, 01:02 »
Front camber is adjustable on mk3's, using the 2 bolts that connect the strut to the wheel bearing housing.
If removing the struts then mark up the positions of the bolts.
Re: mk3 gti camber
« Reply #2 on: 05 February 2005, 02:00 »
nice one and fank u vewy much
just messing cheers mate
u always get what you need on this forum there is always someone that knows
cheers
jay
