Author Topic: MFA reads wrong  (Read 994 times)
Offline UKjarvis
MFA reads wrong
« on: 03 November 2010, 18:14 »
Hi again my MPG reads 99.9 and temps are all over the place any ideas, 8v kjet
Offline lemski
  • 16v
Re: MFA reads wrong
« Reply #1 on: 03 November 2010, 18:20 »
Mine reas 0 and my oil temp is 202 and air -40 on my 16v k-jet. I got told it was because my clocks were knakered. That's all I have if that helps
Offline bodga
  • F reg GTI 16v
Re: MFA reads wrong
« Reply #2 on: 03 November 2010, 19:41 »
clean up or replace your temp sensors on the r/h side of the head (16V), 3 of them. and one on the back of the head also dizzy side is for the oil temp on the MFA. as for the 8v :undecided: are they on top of the oil filter :undecided:
The MPG reads 99 on mine as well, ive checked for cracks in the small bore pipe under the bonnet that runs about by the bulkhead, it sems ok, but it does work breifly when its really cold  :huh:. i aint swappin the clocks for that thou, might cause more harm than good
Offline lemski
  • 16v
Re: MFA reads wrong
« Reply #3 on: 03 November 2010, 19:50 »
Mine works on occasion. Normally when am in trafic it startes working. But when it all cam eout of my donner car it all worked only difference is the clocks.
