Author Topic: aum de cat is this possible  (Read 1221 times)
Offline paulwayman
« on: 02 November 2010, 14:25 »
just i have heard you cannot de cat these engines as you get running problems is this right has anyone got this done on aum engine   :wink:
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: aum de cat is this possible
« Reply #1 on: 02 November 2010, 14:32 »
think there is alot of people that run AUM's with de-cats. It will fail mot on emissions and think you need the lambda elements mapping out
Offline vwblackmk4gti
« Reply #2 on: 02 November 2010, 14:38 »
when i enquired to av my aum de-cat, by long life they said with the obd2 protocols, the vag vehicle av running issues after de-cating
Offline pipbailey
« Reply #3 on: 02 November 2010, 15:09 »
Only issues are engine light due to a higher reading from the rear 02 being out of the threshold, but with one byte change in the mapping the car will run 100% spot on with out any engine lights or fault codes.
Offline paulwayman
« Reply #4 on: 02 November 2010, 15:27 »
thought so as any car should run ok with no cat just cell light need wiping and a map to get best results  :wink:
